Camera settings issue
I have a P4P and with the drone on, the only choice for capturing a photo is Single Shot. If I turn the drone off, I can change that setting in DJI Go 4. But if I change to AEB, for ex, and then turn the drone back on, it resets to Single Shot and there are no other options. Any thoughts on that?
Has this always been the case or were you able to select other options before?
How are you trying to get to the options?
This is how it should work ...
You tap where the yellow arrows point in the order shown:
That should bring up this menu:
What happens when you try this (with the drone connected)?
That's showing that the app is working properly.
But the camera settings are stored in the drone, so if you try to change them without the drone being connected, it won't make any changes.
stovesparesdirectuk
