I did a full gimbal repair Flex cable realign my horizontal on my camera everything works great except it points a little bit to the left what am I missing I can't find in tutorials
Make sure yaw arm and shaft are aligned, set screw square on flat spot of shaft and arm is straight.
I assume you've done a full gimbal calibration?
Sometimes IMU calibration helps.
You didn't say why you replaced the flex cable, or if you replaced any other parts.
We (I) can only assume that there was damage from a crash......
A camera not pointing true forward can be from a slightly torqued (twisted or bent) yaw arm or roll arm.
I did crash it and replaced the yaw arm, flex cable (only because it came with the yaw arm) and replaced the body because of a bend on motor #3. The camera would still face forward after the crash and a gimbal calibration. It was tweak but forward till after my repair. I was able to align the camera roll by leveling the crescent on the shaft, but see no way to adjust the main vertical shaft coming down from the logic board. I see no tweak on the roll arm but you have me wondering, lol.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
