Camera help p3a
Hi all,
I have searched and can't seem to find an answer... I crashed my p3a and had to replace the shell.. and the roll arm... now the gimbal is intermediate along with picture and says signal interference off and on... here is a picture of what I see but if I swap between video and still the picture gets better for a few then back to no signal or this.... I did replace the ribbon cable too....
I had the connector pop loose my circuit board from a crash and had to solder it back on. It was barely touching and was giving me the same issues. Pull out the cables and check the connectors to see if they are loose. Could be your problem.
Also firmware issues could cause this as well.
Reactions: William Denning
jorge sanchez
