aadvanboven said:Nice, but isn't the signal better with the antenna below ?
ianwood said:Also, best make sure there's no chance it can come lose or shift around. If it moves to the side just a little bit, it's a guaranteed crash as it will get caught up in the props.
2trickpony said:Would it be possible to have some kind of combiner so you could have 1 antennas at each corner underneath the P2?
I wonder what Horizon are going to do here:
http://horizonfpvantennas.mybigcommerce ... combiners/
leekawey said:2trickpony said:Would it be possible to have some kind of combiner so you could have 1 antennas at each corner underneath the P2?
Once you have mounted pointing up there will be no point mounting it down. Two antennas will give you extra weight too. I really like the new mounting position that I can go really low to show off while I was miles away lol.
LeoS said:Anyone used RP-SMA\SMA cable extenders to reposition the antennas?
It's possible install the vtx inside the body, use the cable to reroute the antenna to the top part of the body and drill a hole for this supposedly optimal position. No idea about db loss due to additional cables and connectors.
leekawey said:LeoS said:Anyone used RP-SMA\SMA cable extenders to reposition the antennas?
I think people keep their tx inside of phantom might suffer in summer time overheat or burn. I run 3 batteries and it does got really hot. My last cheap Velcro almost fell off when I mounted below.
Regards to gps signal. I didn't notice the different. The antenna is not in the middle above it.
