Battery
What is the best way to leave the battery if not in use. Mines is currently at 97% batt life. I've had it for 3 months now
I drain mine to below 50% if I'm not going to use them within two days and for an extended period of time. I also have the auto-discharge (you can set it using the GO app) set to three days in case I'm delinquent.
Mine are about the same age, and each has been charged 10-15 times (3 packs) - all remain at 100%.
You should also know that -- or you may already know it:)
Battery life references on the battery status screen refers to the total capacity that the battery is able to be charged to. If it shows 97% when fully charged then the battery that battery has lost 3% of it maximum charge capacity. When you store the battery-- store it at a charged voltage of 50 per cent or less-- that is separate from Battery Life.
Fly it down to 50% and let it rest.
If you can't fly, on IOS you may use the SIM.
& Set the App battery parameters to your liking.
RedHotPoker
I leave them at 50%.
If I charge and don't go out and fly I'll take it out in the backyard and fly to 50% then store. I don't like to store the battery above 50% for more than 2-3 days.
Don carlos
