Battery Storage!
I keep my batteries topped up to the recommended storage levels between my breaks from flying but I was wondering if was ok to keep a battery in my phantom during my not flight periods As the battery is in storage mode can it still puff out causing damage to the internal components of the drone??
Cheers
Reactions: joeyjan19
It is generally regarded as better to separate battery and aircraft. Its only the older models with buried Rx power cells that get left on board.
As to getting stuck ? I have one pack that the plastic bar across top middle of pack is slightly bowed up. This means I have to just tweak it down to slide in. It also makes it a bit more tug to get out. Battery is fine though.
Nigel
Reactions: Reaper 56
MS60
