I have read a couple of posts on DJI's Forum in the last few days regarding P4P's and P4A's crashes due to shorted out batteries. Looking at photos of the batteries and the bird's it appears the shorts are a result of loose or not fully seated batteries. I have had my P4A for a relatively short time and taking the battery out is not easy because they are very tight. I am also reading that DJI changed the fittings when they introduced the P4's and that the P3's did not have this problem. I am wondering if over time the battery slots don't expand and this is the cause of the short which also seems to be associated with putting the bird under a heavy load such as using sport mode full throttle or flying in high wind which causes the battery to heat up. My thought is that maybe a maintenance consideration would be to replace the battery if or when it starts to get easy to remove or at least check the gap on the battery. So my question is to those that have had a P4 for awhile, do the batteries over time get easy to remove?
