In other words, it is not normal. A transmitter usually will last 6 to ten times as long as the Aircraft battery.Yes, the transmitter uses much less power and will last at least a dozen flights.
Oh, Alex is right. We didn't know you were not actually flying. I have no experience with that scenario. My understanding is that the Aircraft battery lasts a loooong time just sitting there blinking the lights.Ah right, I misread the post, my bad. If you're using the simulator, then the battery life will not be representative, when flying, the transmitter battery life should be much longer than than the aircraft.
Darren, read his second post, he is just sitting there using the Simulator, so his bird is powered up but not flying. I thought the same thing at first.I can fly 5 batteries in my bird and still have two bars showing on my controller. The battery in your controller would appear to be faulty
Now that would explain it then, fare playDarren, read his second post, he is just sitting there using the Simulator, so his bird is powered up but not flying. I thought the same thing at first.
