Battery charge ‘counter register’ not correct
On my P3P charge times not registering on the counter
On all my battery’s Qty 6
Anyone know what’s going on ?
Reactions: pugwash
Charge cycles are not the number of times you have attached the charger but rather how many times you have replaced total capacity.
For example- two 50% capacity recharges count as one cycle.
I typed out similar answer when he first posted ... but then went back and deleted because of :
"On all my battery’s Qty 6" .....
So my questions are :
1. "All my batterys" .... How many ?
2. Approximate age of each battery ?
3. How many flights you think you made each battery ?
4. What is the average % of battery when you land completed flight ?
From the above we may be able to suggest ...
Nigel
First is to explain how the counter works.
He now knows what the counter's purpose is.
This is the most likely cause for such an error and consistent with past inquiries.
Anything else is likely language differences or observational irregularities.
I agree ... but he MAY have a faulty display ... I just thought it strange he says ALL batterys show 6.
We know that batterys new of the shelf will have 1 or 2 already shown ... so it is unlikely if batterys are used more than a few times to have same displayed results.
Reason for my backing off and asking the questions.
Nigel
What have you seen before in the 2+ years that you've had a P3? Has it worked a treat up until now?
Reactions: JoBe
hcashmore11
