havasuphoto said:OK, I understand the yaw damper may swing the filter into a leg or two...oh well.
Just to confirm, you are not using FPV transmitter or iOSD?? Trying to get an idea of what your flight times should be.
With the above equipment, and the Zen 3d-2 whatever, I'm at 5 minutes 20 seconds before 1st level red flash begins.
No case for my Go Pro 3.....
My total weight is 2.8 lbs(on a home digital weight scale), or 1270 grams. IF, you get a chance, could you weigh your set-up??
If you have a new baby-ya gotta have one of them baby scales![]()
I'm not using an FPV. I do have a garmin GPS I'm considering mounting but haven't yet.
So the setup is a stock Phantom 1, Arris CM3000 with jello mount and the landing gear extensions.
I'm curious on the weight as well and I'll let you know.
One thing which does suck is that I bought a case for the phantom which now is too small after adding the landing gear extensions. They're not convenient to add or remove so now I'm looking at a new case. It never ends.
