ARRIS CM2000 Brushless Gimbal v4 - Default Start Tilt?
Just installed this gimbal last night and WHAT a difference it makes love it. I will set up manual tilt and roll later, but I was hoping someone could help me find a way to make the gimbal start off with the gimbal pointing down a little, instead of dead straight? Kind of like the fixed mounting for the Phantom / GoPro
You need to install the software so you can connect the gimbal to your PC and do the adjustments. I had difficulties until I discovered that I could only make it work on a computer running windows XP 32bit. My new Windows 7 64 bit would allow the software to install but I could never get a reading on the gimbals current setting.
Once you get past that hurdle, you can make adjustments to your gimbal. Do a google search in Youtube for ARRIS CM2000 brushless gimble. The part 2 of that video will show you how to make adjustments once you get your PC and gimbal to connect. Good Luck!
robvalduga
