App helps drone pilots avoid no-fly zones
Check out the FAA's 'be4youfly' app. Strictly for hobby fliers
Reactions: uavflyr
I've found the FAA's map to frequently be inaccurate...
In my admittedly limited experience, AirMap is better.
I've found B4UFly to unstable, frequently crashing. I agree that AirMap is a much better app.
Reactions: uavflyr
I use airmap too, both the phone app and their web based version. Only negative I have is that the phone app doesn't rotate (vertical position only) and it appears to still be using the old 333 exemption guidelines. When you click on 'commercial' it shows a 3 mile radius around airports - removed under the new Part 107 operations.
jeetbuzz360
