anyone tried Lume cube lights
I have, they are pretty cool, a bit of a stinger on the price but solid. I like them because you can spot the AC in the air from a long distance. The app (cube app) allows you to control the lighting while in flight but it has to be within a short range of you. They provide a substantial amount of light and they last a good while on each charge! I’d recommend!
Thanks for the info. They are expensive but I don’t believe that there’s anything better. A couple reviews claims there to heavy but I don’t believe they are.
Ya, that was an initial concern I had along with extra drain on the battery and maneuverability. Both of which have not really been an issue (at least for me). Well worth the purchase in my opinion...
They are a bit heavier , but the main issue is that they pick up the wind and that is really the downfall , they are just to big. Other companies have made micro led and are just as bright and FAA approved.
Wind is always a huge factor as your drone will constantly be warning you about the wind and how it is effecting the drone. Think smaller.
Phantomrain.org
Approved Vendor
Phantomrain.org
Approved Vendor
Can you send me a link. Thanks
Yeah bud, they are awesome if one is too much just turn the other away..this distance of TREX/Bonto is about 50ft. with both Lumes and don't forget intensity is adustable
That’s great! Thanks for the advice. I’ve heard more positive than negative so I’ll give them a try.
Apparently we aren't meant to fly at night time here in Socialist Rep of Australia [emoji849]
