an odd effect when photographing auroras on a ship
You also have add in the crop factor for the sensor size of the camera. The example above uses a full frame camera. Those cameras have a crop factor of 1 to 1. Your Osmo uses a 1/2.3 sensor that has a crop factor of 1/5.62. So if your Osmo has a 20mm lens you are going to be around a 5 second shutter length before seeing star trails. 20mm X 5.62=112.4 , 500 divided by 112.4=4.45 seconds.
Thanks for the inputs. Due to the length of the artifacts, I don't believe they are due to the earth's rotation. I varied the exposure times between about 10 and 20 s. Maybe long enough for very short tracks, but I'm pretty sure it's due to camera movement. I'm going to get out one night soon and do some testing. I will report back.
Man I don't see anything wrong with any of your pictures,I was mesmerized couldn't stop watching videos then watched the pictures they were so nice I could hear the wind and feel the cold you have one of the best jobs on earth!!Great Job!!
Thanks for the kind words. It is possible to obtain much higher quality images, but it's not so easy under those conditions. For a bird in flight, you have to keep the camera on it while trying to maintain your footing on an icy and moving deck, the bird may often fly out of view behind parts of the ship, spray gets on the camera lens, the light conditions are poor, the wind is howling. That's all part of being in the Arctic, and I love it, but it doesn't make photography easy!
You may be a very skilled photographer. I did not say you weren’t. But because the light was very poor, and you were on a moving boat, you were not able to shoot at a fast enough speed to obtain the sharpness needed for a good picture. Wondering why you have star trails is silly! Of course you will have star trails. Of course the northern lights will be blurry! The stars are moving, you are moving. The northern lights are moving. A very difficult subject to shoot at the best of times.
I obtained an Osmo+ for photographing auroras on a ship during a trip to the Arctic Ocean. Some of the photos are posted here. The auroras look pretty good, but there are star tracks. This seems contradictory -- how can there be star tracks (which indicate motion) if the gimbal remained still enough to produce good images of the auroras? I can think of only one possible explanation: when the exposure starts, there is briefly a little motion before the camera stabilizes, and this is sufficient for the relatively bright stars to produce tracks. If I go on another such trip, I might get someone to hold an obstructing screen in front of the lens and then move it just after I start the exposure.
where is the link to the photos?
You think my post is silly. I think your comments are silly. I don't care what you have to say. You don't care what I have to say. That's fine with me. So there is no need for you to continue to participate in this thread.
Now to set the record straight. It shouldn't matter that I wasn't able to hold the camera still under the conditions on that ship. The DJI Osmo+ should have taken care of it. But it didn't work exactly as it should have. The stars appear to move, but the aurora doesn't. There must be an explanation, but you haven't shed one photon of light on it.
Last word in above sentence.
The question was why the star trails with the Osmo? The other pictures are really not a concern. In fact the ice floe pics are cool.
I have an Osmo, not Osmo+, which I've often used to record time-lapse and long exposure.
Since the first, there has always been a notable slow wobble caused by the gimbal motors.
Where there is a breeze, the wobble can be accentuated; I find a wind break for the camera helps a little sometimes.
I've tried the calibrations, but the wobble has never been eliminated.
Only locking the gimbal will keep the camera completely stable; which obviously isn't ideal for a few reasons.
Not sure if your Osmo+ suffers the same, but it would be my first guess.
Now, when intending a timelapse, I just assume there will be wobble and do what I can to eliminate it with post image stabilization.
That may not be so easy to overcome with star trails on long exposures; where you could be suffering from both the wobble and the movement of the stars combined.
I'd suggest trying a shorter long exposure, with a higher ISO setting (just not too high) and perhaps combining the images after stabilizing in software.
I would really like to develop an app, in a similar vein of ActiveTrack, which introduces star tracking movement to the gimbal or perhaps just automatically moves the gimbal to counteract the Earth rotation. With a GPS location, this shouldn't be impossible - but it could only ever be as accurate as the Osmo and DJI's SDK allows.
A gimbal will somewhat stabilize and smooth out movement, but it won't be rock solid. It doesn't allow the camera to lock onto a point in space while the rest of the world moves, spins and shakes. It's meant to create smooth movement. I just don't think the OP understands the limitations of a device like the Osmo, combined with a slow shutter speed, combined with a rocking boat, etc. etc. Not a good combination. I'm amazed that the photos came out as well as they did considering all of the factors. Basically, a gimbal is meant for videos and a tripod is meant for photographs. Neither works well for photos taken from a rolling ship.
The star trails (perfectly matched squiggles) are obviously due to camera shake that the Osmo could not react fast enough to and were bright enough to quickly burn into the image. The aurora is no doubt a bit blurry also, but was not a bright enough object for the quick shake to be obvious. Photoshop out the star trails and you wind up with decent photos of the aurora.
Reactions: Trackerputnam
I purchased the Osmo+ for a one-time application: photographing auroras from a ship, a moving platform that requires a gimbal for long exposures. I recently decided to brush the dust off and give it a try on Comet Neowise. I first tried holding it in my hand and pulling the trigger to activate the stabilization. The results were similar to the previous results on a ship. Star trails on most of the photos, but a few of them came out OK. Then I tried it on a tripod under ideal conditions. There was no wind, the sky was clear, and the comet was easily visible to the naked eye in a dark location. I used an iPad to take the photos so that there would be no disturbance. Still the same problem. I found discussions online of others having similar problems. The Osmo+ is a good device for certain applications, but it has serious problems when it comes to long exposures. It is very puzzling that this problem even occurs with a tripod. It has nothing to do with the Earth's rotation. The exposure times were not long enough for that to be a problem, and the motion isn't in the form of arcs around Polaris.
I did one more test with the Osmo. I used it indoors with the windows closed so that there wouldn't be even the slightest draft of wind. I did a time lapse for more than two hours, and there were many times when the camera moved as if bumped. However, the camera was isolated from any disturbance. I had noticed the same problem when doing time lapse movies outdoors but thought it might be the wind. This device, be it the model itself or this particular one, has problems. Whatever it is, I suspect there is some flaw that would explain all of the problems that I have had with it, ever seen it was brand new. This device had the potential to be an awesome stabilized camera. Despite the flaws, it is capable of producing amazing results. However, due to the flaws, which others have reported, it is understandable that this device is no longer on the market. I wonder if DJI drones have any flaws that are due to the same cause (but may not be as noticeable with a drone). I don't expect to post any further updates on my experiences with this device. Thanks to those who responded in this discussion.
Shaking off the dust on an old thread. My original desire was to find a way to take long exposures of auroras on a moving ship. I tried the Osmo+ several times, but there were always star tracks in the photos due to the motion of the camera, not the rotation of the Earth. Since the last post here, I gave it another try in 2022, had similar results, and gave up on the Osmo+. I obtained a Nikon Z6ii for photographing auroras on land. I used similar exposure times, and got great results with no star tracks. There is no doubt that the Osmo+ does not compensate sufficiently for motion for this type of photography (although I did get some nice stable videos with this device). On a recent sea trip, the auroras were so spectacular that I mounted my Nikon on a tripod on the deck of the ship. Despite the motion of the ship, I got some fairly nice photos. Those photos also have star tracks, which consist of complex orbits. With the Osmo+, the tracks resemble curved line segments (but with some small wiggles), which suggests that the failure to compensate is mainly along one axis. Various photos that I obtained with different devices are posted here. I recently obtained the DJI RS 4, which is based on related technology but is a much more substantial device that can handle much better cameras than the one that comes with the Osmo+. I did some preliminary tests involving similar exposure times on land and obtained photos without star tracks. This suggests that the combination of the RS 4 and a good camera will make it possible to get excellent aurora photos from a moving ship.
There is no reason why a gimbal couldn't be rock solid, and in fact initial testing of the RS 4 suggests that it is close to rock solid. I hope to get an opportunity to apply that device on a sea trip. The star trails are correlated in some cases, but they are not perfectly matched (as is easy to understand by considering rotations of a camera around all three axes). The Osmo+ does indeed produce smooth movement, but it is designed to remain aimed in one direction when the trigger is pulled. It does a pretty good job (the camera appeared to remain aimed in the same direction as I moved my arm around), but it's not good enough for high quality aurora photography on a moving ship.
fighterpilotlast
