Hello people.
After a GPS flight I turned to manual today to practice. It was about 20 ft above a grass area. I did some forward backward and side moves and it tilted on a sharp angle and it crashed. 2 broken props and bent gimbal arm. Battery was still in contact. It was on. I turned it off and put replacement props. I turned it on and there was just a beeping sound. The sound is the same as the sound of upgrading the firmware. I opened it, removed gimbal and saw that the wifi metal box had a dent . I opened the wifi box. The 2 boards look fine inside. I straightened the metal box. Apart form these physical damages I can't see anything else.The Phantom doesn't even connect to assistant. Any opinions? I checked all the connections and they looked fine. No fried plastics smell no burnt cables. ESC's look fine I don't know about the motors but they turn fine with hand rotation. I don't think a video would help, so I don't post one unless you want to hear the sound.
Thank you for your attention.
