advanced controller ?
What is the controller frequency used on the advanced controller to control the air craft
? Is it 5.8 GHz If it is can it be linked to the P 3 standard. Saw somewhere that the advanced controller had more power.
The P4 Advanced uses 2.4GHz but even if it was 5.8, it would not be at all compatible with the Standard which uses old-tech wifi rather than Lightbridge.
Reactions: TaffyBrian
Was thinking more range but if it is light bridge your right it is not compatible so maybe if i can try this. I think I can get that range by using Litchi app and way points. I already have the ARGtek setup just want to get out to 2 miles. Not sure how safe that is but then I am looking into a tracker also. The reason is there is a large construction site I would like to monitor but it is just out of range from me.
