Adobe Premiere 4k to 1080p
So far I have been working exclusively with 4K video with 4K sequences. I would like to start experimenting down scaling to 1080 to see the differences and also just to become familiar with the process should I have have this as a requirement.
Am I required to change the actual sequence settings to 1920 x 1080, or, am I able to leave the sequence setting at 4K and simply change to 1920 x 1080 within the export settings? Not understanding if there is a difference here.
Always shoot in the highest resolution and then step down on the export. I shoot 4K and then downsize to the final output that is needed.
Better to always have room to take away because you cant add back.
Hi Gary - thank you very much for the feedback. Yes, I completely agree and I always shoot in 4K. However, what I am wondering is if within Premiere, in order to downsize, is changing to 1920x1080 within the export settings sufficient, or, do I need to actually change the sequence settings to these values prior to the export? Essentially, is changing the sequence to 1080 vs. within the export settings basically the same thing?
I just do it in the export. From what have seen on the Adobe forums, they also use the max resolution and then step down in the export.
Reactions: Pharm and InforGuy
Works for me. I'll give it a whirl. Thanks again.
You may not see any real differences if you're not doing much to the footage. One of the huge benefits to 4K, that you can do a lot to the image and retain detail for a beautiful 1080p finish. When the 4K files should be downscaled to 1080p, there are mainly two workflows:
A: First edit the project in 4K then render it in 1080p.
B: First batch convert/render all 4K clips to 1080p then edit the project in 1080p and smart-render.
tpren3
