Adjusting yaw rate...???
I was wondering how to adjust the settings for yaw rate in the Phatnom assistant software if I wanted to get a smoother rate when doing a pirouette while flying. Whenever I am doing a pan shot that needs the camera to turn with the shot, as soon as I put in a little rudder to yaw the P2V+ to one side to track the shot it abruptly starts to turn rather than easing into the turn. So if I wanted to adjust the settings in the assistant software to make this initial turn a little smoother, almost like adding in expo (if you will) what should my yaw settings be from where the stock settings are at right now???
Thanks and cheers!
-Clint
Thanks and cheers!
-Clint
This is another yaw modification that is in use. So if you're handy with solder iron you have two choices as the two I posted are the basically the same.
https://www.youtube.com/watch?v=hyUqn9Xq_mo
https://www.youtube.com/watch?v=aSpw_Ar1HZc
I use one and love the way it works for panning.
Don carlos
