A couple questions about Go when used with P4P Pro v2
Sterling Heights, MI
I’ve flown a standard P4 for sometime, my version of Go didn’t change the other day when I was lucky to buy and start flying a P4 Pro v2 but some new setting appeared and an unexpected behavior. I hope someone can help answer some questions.
First: I’ve set video to record at 1920x1080p @ 30 FPS or higher using the MP4 container.
What I get are two files. One is the MP4 with the specs I set. But I also got another file, named the same except using the .mov extension and container but it’s always at 1280x720 @ 30 FPS.
Why? How can I get rid of it, I surely don’t need it, I already have the file I need. This did not happen with this same settings and version of Go.
Next: What does the Sync HD Photo setting do?
Another question: previously, to take a photo I pushed the photo button and i would immediately hear the shutter sound and capture a photo. Now I have various things happen. Sometimes, rarely, i can just push the button and get a photo, like before. More often I have to push and hold and might get a photo, maybe. Yes, I’ve discovered I can press half way, achieve a fine focus and then fully depress. Thing is, when I do that I get a photo only 75% of the time. Sometimes even if I half press to focus I still don’t get a photo. Can any help me better understand, put simply, how to best snap a photo easily.
Thank you in advance.
P.s., I may have other follow up questions :)
the other day when I was lucky to buy and start flying a P4 Pro v2.....I’ve set video to record at 1920x1080p @ 30 FPS or higher using the MP4 container.
I don’t have a P4Pv2, but when the question about two files was asked here a few weeks ago, a response was that the second file is normal and it’s a low res thumbnail file in a separate thumbnail directory. I’m sorry that I am not able to confirm or contest that info myself. I’m just passing along the link in case it helps at all.
Reactions: JoBe and Capt KO
Thank you for that link. I’ll add my comments on that issue there.
jeetbuzz360
