GetaGrip said:It seems the Phantom Tool hack no longer works, it will open and you can switch to the H3-2D mode but it doesn't hold and reverts back to Vision mode on exit.
Geert said:gfredrone said:Has anyone completed the update who has the 7th channel hack? Does it still work?
Yes, it works fine.
However, after installing the updates you have to uninstall the hack, power cycle your Phantom and do the hack again.
After that, it will work fine.
Geert.
Yep same thing here, what are we missing?wgasja said:i must be doing something wrong. each time i get the hack to work and the camera moves by using the tilt lever on the tx when i power down the phantom and power it back up it reverts itself back to vision mode and i have to use the phone app to tilt the camera.
GetaGrip said:Yep same thing here, what are we missing?wgasja said:i must be doing something wrong. each time i get the hack to work and the camera moves by using the tilt lever on the tx when i power down the phantom and power it back up it reverts itself back to vision mode and i have to use the phone app to tilt the camera.
wgasja said:GetaGrip said:Yep same thing here, what are we missing?wgasja said:i must be doing something wrong. each time i get the hack to work and the camera moves by using the tilt lever on the tx when i power down the phantom and power it back up it reverts itself back to vision mode and i have to use the phone app to tilt the camera.
I'm using the standard P2V setup and Geert is using the RP gimbal setup, so maybe that could be the difference
RCRookie said:DJI is doing this intentionally. They could easily fix this for their Vision owners.
Sad business practices.
cougar said:Anyone tried to install the "hack" on 3.0 after the update was done or do you have to install the "hack" with earlier software?
Also like to know if it is possible to install this on one computer and then move it to another?
My main computer is a mac but have an old laptop running win xp so if I can install on the windows machine and then move it over to my Mac, with it all stay installed?
Know people say install windows in parallels or bootcamp but don't want on my mac.
Thank you for any help.
ResevorDG said:cougar said:Anyone tried to install the "hack" on 3.0 after the update was done or do you have to install the "hack" with earlier software?
This should be no problem. I also use a Mac. I borrowed a buddies XP laptop to do the upgrade. Since then I have used my Mac config software several times and everything is just fine.
