What are the symptoms if you enter in the wrong number on the Z axis?Acill said:I would change it to 14cm yes.
Nothing that I've ever seen. One of my phantoms is running -999/999/-999cm and it doesn't affect flight at all....not sirens it actually has an effect on a significantly larger craft.havasuphoto said:What are the symptoms if you enter in the wrong number on the Z axis?Acill said:I would change it to 14cm yes.
Interesting...well, I put I'll change it anyways.ElGuano said:Nothing that I've ever seen. One of my phantoms is running -999/999/-999cm and it doesn't affect flight at all....not sirens it actually has an effect on a significantly larger craft.havasuphoto said:What are the symptoms if you enter in the wrong number on the Z axis?Acill said:I would change it to 14cm yes.
havasuphoto said:Interesting...well, I put I'll change it anyways.
Yes it is-and I have it a negative 14cm now. Also changed my 1st level warning to 14.2 volts-just to I can watch this other battery-to make sure it doesn't drop as fast at Battery #1 did Today.ElGuano said:havasuphoto said:Interesting...well, I put I'll change it anyways.
Btw, it it's on a stalk above the MR like everyone has it, your Z value will be negative, not positive.
OI Photography said:The list goes on, but those are the most compelling arguments for me. And we haven't even started to discuss telemetry or other goodies...yet![]()
ElGuano said:OI Photography said:The list goes on, but those are the most compelling arguments for me. And we haven't even started to discuss telemetry or other goodies...yet![]()
I think I'm probably convincedHow good is the radio?
Yes, not good when you are landing and the retracts go down and your lights go off... I flew it for another 5 minutes... As I landed in the dark, it tricks your eyes when the LED's go off...... I'd rather have them on until I turn them off...ElGuano said:Not good? Looks pretty sweet to me! I can see why you wouldn't want the side-facing lights to go off with the gear down, as you're more likely to be eye-level with the hex and unable to see the flashing lights on the bottom. But the effect is really nice.
Yes... They work on 12v... The strips are hard-wired (soldered) to my power source...OI Photography said:Well the retracts and the lights do all look great...when they all stay on that is.
Clear up my confusion if possible...how are the lights under the arms wired differently than the ones at the tips? Are the ones under the arms on 12v instead? I was just figuring there might be some way to let them feed off the same source until you can get more channels on the radio.
I think I'm sold also... Have to read up more, but what I see I like... I thought the Taranis you were using was a $500.00 plus unit... I almost bought a (used) Futaba T8FG SUPER for $325.00 (most are going for $450 and up - I think they are discontinued)... I liked the fact that they had so many 3 way switches on it.Speaking of which, here's a good place to start reading to get an idea of what the Taranis I mentioned is like: http://www.alofthobbies.com/frsky-taran ... combo.html
Lots of cool bells and whistles you'll see described there, but it boils down to three main things (for me anyway):
-Flexibility. Anything you can conceivably want your controller to do, you can do it with the Taranis. 16 channels out of the box, 6x 3-way switches, 2x 2-way switches, 2 pots, 2 sliders, and the easiest programming you can get (see below).
-GUI. Connect the Taranis to a PC and you can do all the programming via a simple but powerful GUI, which will let you simulate/test all settings before putting on the controller, as well as burn/edit configuration files in just a few clicks. Open Source Firmware FTW.
-Value. C'mon...all that, plus telemetry capability, with a receiver, for less than $250. Also, every single individual component of the Taranis (from the shell to the labeling stickers to the LCD display to the switches) is available for purchase...inexpensively...and easily user-replaceable, if you ever want or need to do so.
Thanks. I don't want to really tear down the whole video system. But, I'm going flying this morning, so I'll determine just how usable it is.ElGuano said:Electrical interference has to be approached systematically. You can try wrapping some wires in grounded steel weave or foil lining, but the best way is probably to tear the video system off, run it independently to verify the signal is clean, and slowly add it back to the MR to see what point you get interference. You may need a less noisy power source, switch out becs, etc.
And weight of course, that's a whole new ball of wax. I haven't even started counting the grams on mine, but it'll be a full teardown when I do.
havasuphoto said:@Ol; when you tin the wires to put the bullets on-do you twist the wires first? also, do you hold the soldering iron on the back side of the wire, and draw the solder through the wires that way?
I'm getting ready to do bullets....so I'm a little unsure of how to tin the wires.
Thanks
