3 Blade rotors for P4 Pro+
I have recently come across a 3 blade rotor by Llguz Carbon fiber claiming to work on the P4 Pro+. Anyone have any experience with these?
Harry
Thank you both. I only heard that they were quieter. If there isn’t any increase in performance I wouldn’t mess with them. I have been pretty lucky with the P 4 pro plus.
I am notorious for putting the original phantom, happy to, and if he three in the water. The P2 was because of rapid descent before they fixed it.
Let’s assume they are quieter- if the blades are at or close to the profile of the standard issue props you should expect lower RPM operation for a given thrust. This might seem like an advantage until you consider that operating the motors outside the designed RPM range is likely to result in lower efficiency (less flight time).
axipap
