Vision plus distance
Okay, to the point.
I have phantom vision plus that's two weeks old. It's a clear field, sun shining, 9 am peeerrrrfect setting.
Why can I only get 1200 feet (365 meters) distance when connection is broken?
Are you not supposed get up 700 meters. I was at least hoping for 500 to meters
I just received a second radio. I'm going to bastardize it and not touch the original.
Hope to get some value for my dollar
Any input ???
Thanks
Darrell
darrellkh said:
Okay, to the point.
Any input ???
Thanks
Darrell
You should at least get 800-1000 meters of range, like mine unless you did not set to FCC mode which should beep twice on turning on.
Okay, you got me. I'm a newbie don't have a clue. I've owned the vision plus for two weeks. Reading some message boards I was uncertain to.
the fact that you thought FCC/CE mode only affects altitude shows that you have not fully read the manual.
#1 Make SURE you are in FCC mode
#2. Do you have limits set in the software that limit your range?
#3. Are you aiming your transmission antenna straight up to the sky so that the long side of the antenna is facing the Phantom?
#4. Are you aiming the topside of your range extender towards the Phantom?
Ya my bad, I'm a guy, if all else fails ready the instructions
Yes the radio goes beep, beep when turned on. I am in FCC mode
I'll check the settings in the software.
Anyone know where to buy a bigger antenna and the 6" coaxial wire for the radio?
I bought another radio to tear apart
Nip
