VIP TFR over FT. Benning, GA and Opelika, AL on Friday, March 8, 2019 I
Tennessee
Inbox
  • Trouble viewing this email? View it online.
    FT. BENNING, GA AND OPELIKA, AL ON FRIDAY, MARCH 8, 2019
    Click here to enlarge image
    A NOTAM has been published (FDC 9/3789 and FDC 9/3790) that will affect flight in the area during President Trump's planned visit.
    30 NM RADIUS TFR
    On the LAWSON VOR (LSF) 097 degree radial at 0.3 nautical miles.
    From the surface up to but not including 18,000 feet MSL.
    Times:
    11:00 AM EST until 12:15 PM EST Friday, March 8, 2019 (Eastern Standard Time)
    2:30 PM EST until 3:45 PM EST Friday, March 8, 2019 (Eastern Standard Time)
    10 NM RADIUS NO-FLY ZONE
    Times:
    32 NM RADIUS TFR
    On the TUSKEGEE VOR (TGE) 073 degree radial at 15.5 nautical miles.
    Times:
    10:45 AM CST until 2:00 PM CST Friday, March 8, 2019 (Central Standard Time)
    12 NM RADIUS NO-FLY ZONE
    Times:
    Affected Public Use Airports
    KCSG Columbus
    KEUF Weedon Field
    82A Marion County
    KAUO Auburn University Rgnl
    06A Moton Field Muni
    7A3 Lanett Muni
    KCSG Columbus
    41A Reeves
    KPIM Harris County
    07A Franklin Field
    KLGC Lagrange-Callaway
    Additional Notes:
    No pilots may operate an aircraft in the areas covered by this NOTAM (except as described).
    Except as specified below and/or unless authorized by ATC in consultation with the air traffic security coordinator via the Domestic Events Network (DEN):
    A. All aircraft operations within the 10/12 NMR area(s) listed above, known as the inner core(s), are prohibited except for: approved law enforcement, military aircraft directly supporting the United States Secret Service (USSS) and office of the president of the united states, approved air ambulance flights, and regularly scheduled commercial passenger and all-cargo carriers operating under one of the following TSA-Approved Standard Security Programs/Procedures: Aircraft Operator Standard Security Program (AOSSP), Full All-Cargo Aircraft Operator Standard Security Program (FACAOSSP), Model Security Program (MSP), Twelve Five Standard Security Program (TFSSP) All Cargo, Or All-Cargo International Security Procedure (ACISP) and are arriving into and/or departing from 14 CFR part 139 airports. All emergency/life saving flight (medical/law enforcement/firefighting) operations must coordinate with ATC prior to their departure at 678-364-6103 to avoid potential delays.
    B. For operations within the airspace between the 10/12 NMR and 30/32 NMR area(s) listed above, known as the outer ring(s): all aircraft operating within the outer ring(s) listed above are limited to aircraft arriving or departing local airfields, and workload permitting, ATC may authorize transit operations. Aircraft may not loiter. All aircraft must be on an active IFR or filed VFR flight plan with a discrete code assigned by an air traffic control (ATC) facility. Aircraft must be squawking the discrete code prior to departure and at all times while in the TFR and must remain in two-way radio communications with ATC.
    C. The following operations are not authorized within this TFR: flight training, practice instrument approaches, aerobatic flight, glider operations, parachute operations, ultralight, hang gliding, balloon operations, agriculture/crop dusting, animal population control flight operations, banner towing operations, sightseeing operations, maintenance test flights, model aircraft operations, model rocketry, unmanned aircraft systems (UAS), and utility and pipeline survey operations.
    D. UAS operators who do not comply with applicable airspace restrictions are warned that pursuant to 18 U.S.C. section 3056a, 10 U.S.C. section 130i, and 6 U.S.C. section 121 (as amended), The Department Of Homeland Security (DHS), United States Secret Service (USSS), and The Department Of Defense (DOD) may take security action that results in the interference, disruption, seizure, damaging, or destruction of unmanned aircraft deemed to pose a credible safety or security threat to protected personnel, facilities, or assets.
    E. FAA recommends that all aircraft operators check NOTAMs frequently for possible changes to this TFR prior to operations within this region.
    Airspace Online Course
    - Take Course -
    Intercept Procedures Card
    - Download Here -
    Don't leave the ground without AOPA's Pilot Protection Services. We assist in an average of nearly 4,500 aviation-related legal matters annually, including pilot deviations and TFR incursions. Visit www.aopa.org/pps to learn more and start protecting your flight activities.
    You are receiving this TFR notice because you are a member of AOPA. To continue to receive this important member benefit, please keep your membership current and your contact information updated.
    Have Questions? Please contact the Pilot Information Center at
    1-800-USA-AOPA (872-2672)
    © Aircraft Owners and Pilots Association
    421 Aviation Way
    Frederick, MD 21701
    (800) 872-2672
    (301) 695-2375 Fax
    421 Aviation Way, Frederick, MD 21701​
  • Reply
  • Reply All
  • or
  • Forward
Send
Settings
[email protected]
[email protected]
Reactions: BigAl07
