Video file corruption - Faulty camera or ribbon cabe?
Woodstock NY
Phantom P4
After flying all day recording video with no problems, the last few files that were recorded had issues. There are white pixels and artifacts in the shadow areas, and dark vertical banding in the highlights.
I ran a few tests using different SD cards, I tried resetting all camera settings, but these problems are in all video and still RAW files. See sample file the link below.
My research tells me that it could be a loose connection or bad ribbon cable. Has anyone experienced a similar problem and how did you resolve it?
To see the issue you may need to view this on Vimeo in Full Screen mode.
Hi
Did you solve this? I have the same issue and i haven't found a solution. Firmware update doesn't seems to work.
