Unofficial software development/reverse-engineering?
Sweden
Hello!
Is there anyone who have attempted to reverse-engineer the firmwares, and also the Ground-Station softwares, to get some information useful for custom
application development? Since there is no official SDK, I am very interested in all notes and documents you coders out there might have on the subject.
Please share :). PM me if you have some information.
I know for cheaper drones like the AR.Parrot, there were some quite fun possibilites for custom-apps aiming specific puproses.
Any IDA-database, or just scribbled notes would be appreciated! Actually all/any lowlevel-information you people have on the P2V+, would be appreciated if you shared. :)
Sinc, SmoothS
I have decompiled all the java source code for the DJI Vision App for Android.
I'm currently working on removing the waypoint restriction and 500m distance limit. I've figured it out but I am running into re-compiling errors I just have to sort out.
A shame that dex2jar had trouble with VisionCmd and VisionGsCmd (dji.midware.tcp.vision).
Those are likely the most important classes in terms of determining the actual data being communicated.
ilovecoffee, if you get a chance, perhaps you could try Procyon as well? When I was doing decompiling for another package a while ago, I had some luck using this to get some of the trickier sections of code.
Awesome work guys! Will look into your stuff asap ilovecoffee :). Am an aspiring Java-coder myself, mostly been coding x86 assembly for many many years. But time to go up to HLL's. So Java is my first OO language, and messing with drones is a lovely combination of my favorite hobbies. :) (also messing around with my AR.Parrot Drone 2.0)
Keep up the good work! I hope to see more contributions, maybe we can create a dedicated page or somekind of github for Phantom-projects. :)
I will upload and share my findings as soon as they are decently useful and cleaned up. :)
Sinc. SmoothS
I think this subject deserves a sub-forum of its own (and maybe it already exists - I don't know), and although I am not a S/W freak, I am very interested in this also (along with the detailed schematics of the DJI parts). So I will certainly stay tuned.
Having said all that, will DJI not resist all this research and potentially (if they monitor this forum) request it not be promulgated/propagated/popularized (not that they have any rights of this sort here - I don't know)?
ilovecoffee said:
...although not clever enough to figure out why the hell I'm having compiling errors! So close!
If you're trying to recompile directly from the dex2jar output, refer to my previous comment - some of the classes couldn't be decompiled, and other methods were converted to assembly.
If I remember correctly, this is either due to binary instructions embedded in the code, or some sort of encryption on those particular pieces.
That's right. I wasn't trying to recompile based on a dex2jar output, that was only to help my understanding. I then edit the smali files which is more of an assembly language based on what I THINK is the correct edit, but am unable to recompile it. If you have time, please see if you are able to decompile and recompile the DJI Vision apk using apktool without any errors. I've tried it on both my desktop and laptop without success so I'm not sure if it's a configuration error I'm having or if apktool is having issues recompiling it.
Do you fancy sorting out the intermittent failure of the visual low battery (20%) warning ? Sound is ok, but no screen based warning.
..and now I too am getting the not enough power to return home problem even at 30% plus battery charge.
Getting mighty sick of inconsistent performance DJI - ok !!!!!!
The customer shouldn't have to address fundamental design flaws :evil:
arthurbiss
