Total Newbie Replaces Camera on P4P with Laser and Causes Havoc!!
Ok, now that I have your attention...
1) I am a total newbie, though I have flown helicopters, am SAR, and a former electrician.
2) I haven't caused ANY havoc.
3) I AM doing a survey project - I've returned to school and am in my last year of getting my Geomatics/Land Surveying degree..
4) I AM going to try to mount a LASER pointer on the P4P gymbal and use it to do some survey tests for my Senior Project. P.S. at 59 yrs. old, I'm a 'senior' in more ways than one!
Does anyone see why taking the camera off would mess up the flight capabilities/functions of the P4P?
Reactions: BillyN
You'd be flying blind. The P4P can carry a lot of weight so putting the laser below the camera might be a better solution.
Reactions: jephoto
Picture of laser ?
This Rifle laser pointer weighs 1.9 oz. or 53.7 grams
It is within theFCC limit of consumer laser power - 5mW
and has non-rectangular dimensions of 6.2 cm L X 3cm H X 3cm W.
Right. It's only to do some hover accuracy tests so the drone will never be more than let's say 50 meters from me. 90% of the time about 10 meters from me. And I can't mount it to the bottom of the camera because I need the gimbal to point straight down, and the laser on the bottom of the camera would interfere with that rotation. Thanks for taking a moment to reflect on it though!
You can get boards that fit across the bottom of the landing gear, they are designed to prevent the camera getting bashed if you land heavy on rocky ground, you could fit one of those and then mount the laser on that, only downside is that you would need to hand launch each time
Reactions: jephoto
Those type mounts can be placed behind the camera with the laser mounted on top of it pointing down. Shouldn't interfere with camera, or takeoff and landing. Even if laser is strapped to a leg, ballance and weight shouldn't be an issue.
P4P’s are easy to hand launch if need be
Arcadia JC
