Signal problems with the ground station
hello !
I have problems with the ground station , and phantom 2
Namely , I have just 200-300m range .
Even if I fly over 10m antenna , signal fading .
That is to say , I have 3 bars signal , I 100m away, and the signal disappears completely , and in a few seconds again returns to the three dashes , the same is if I'm away 10m or 300m .
When I surpass 300m, but the connection is completely disconnected.
What is the problem?
I use the iPad.
It does not matter if you lose signal as the transmission of data is done prior to takeoff. It then uses that data to fly the route.
Johnboy94
