Samsung Galaxy tab s2 for phantom 3 pro
Guys please note there are a few version of the S2. In N.A. there is last years vr. Which is model #T710 and the new model which is the T713. (8" vr.)
I could not get the T713 to work properly with the DJI App, it had a LOT of trouble connecting to the USB. When I returned I got the older model T710 and it works just fine.
When using more than one app and changing between them I still have to go into settings and tell the P3 apps they aren't the default for the USB. Then I'll get to select which app to use when when an app is fired up. With Android 6 we no longer have the prompt to tell Android to use this app "only once" :(
Don't know why they changed this in the latest Android vr. because it's a pain!
No noticeable video lag here.
It seems that the android 6 issue is related to the TAB S2. I have the SM-T715 and it works the same as your T710. The solution was to use only GO on this tab as it is a pain all these swapping in the settings.
Go to - Settings:
About device:
Tap on 'Build number' 7 times until developer options are unlocked
Go to - Settings:
Developer options:
Set the following:
USB debugging = OFF
USB configuration = RNDIS
Note: Reboot will reset this to default MTP
S2 will run perfect!
The S2 has a better display for half the price of the Apple product.
Reactions: Vichian-Bruno
Drone Sky Hook
