Rit dyed my front props today.
Saint Clair Shores, Michigan, USA
Even though the Phantom has bright LEDs. I wanted a better way to tell the front from the back, when doing LOS flying. This REALLY helps. I also added just a small piece of red flex conduit to the front legs.
These came out way darker than I wanted, but now they have grown on me. It's really easy to do. Just get a thing of Rit Dye from a fabric/craft store. The powder or liquid is fine. Get a throw away pan from a dollar store. Boil water in it. Put the dye in. Stir with a throw away stick. Turn it way down. Throw your parts in there for like an hour. Stir every 10 minutes.
DO NOT dispose of the dye in a white sink. It will stain it permanently. I took the pan right outside and dumped it into a sewer.
For prop colouring - I use permanent marker pens.
Just a note : in the old days - we used to boil props to supposedly relieve moulding stresses particularly nylon ones.
I would be careful of too much heat on these props .... just my opinion.
Nigel
Nigel
Thanks. I probably had the water only about 180 F or so. The initial boil (212 F, obviously) was just to get the dye mixed up well.
You have to be careful with paint because of balance.
It is common to balance a prop by either carefully sanding back of heavy blade or adding thin coat of lacquer / varnish to back of light blade.
Helicopter - we often use a sliver of clear or coloured tape on light blade.
I do use paint at times for prop tips on my bigger models but I would not here, as we rely on well balanced quad props. Also to avoid vibration and camera problems.
Ink or dye .... no weight !
Nigel
jumperswaves
