Ribbon cable replacement
I recently replaced my ribbon cable on my P3S because it was ripping due to the camera hitting it, the ribbon got unraveled so it wasn't pointing straight down, so I took off the cover that covers the ribbon and tried fix it myself, but anyway, after replacing the ribbon I put everything back and now it doesn't work, but it makes that noise when you power the phantom on and that's all, the camera and the gimbal doesn't work. Any suggestions besides spending 250$.
Did you replace it with a genuine DJI replacement cable? Many posts on the forums of non-DJI cables not working.
Next, are you positive that you seated every connection point properly? Each connector has a switch (not sure why it's called a switch) that has to be carefully lifted which releases the connection, then when the new cable is inserted, the switch has to be carefully closed in order to make proper connection.
RF_Geek
