Recommend me an FPV system!
d4ddyo said:
badbrad97 said:
I am not familiar yet with RHCP and LHCP, what is that?
It is the direction the Antenna is wound. Yes... google your tx and rx. that's how I found what channels to try and how to tune.
OMG. This is so simple now that I have found the frequency charts for my equipment. (All missing from my packaging)
The 32 channels on my Boscam RX-LCD5802 correspond to the 32 channels on the 600mw Boscam TS832. I do not have the ImmersionRC after all (See charts below) I also noticed that frequencies on the 7 channel 400mw correspond to one group straight across on my receiver.
When letting the receiver scan for channels on its own. IT DID NOT FIND THE CORRECT CHANNEL! Once I MANUALLY input the channels the picture is crystal clear. I have not done any distance testing but I can tell already it is the best it has been yet.
Hope this helps someone else with the Boscam RX-LCD5802
Tested last night and got 1000 meters easy (no breakup) with LOS. I also went the other way and got 600 meters at 100 meters high with woods and houses blocking me. This was is what I really needed for real estate video.
Thanks for all the help.
Boscam TS832 on channel 32
Boscam RX-LCD5802 Manually entered C-2
Antennas IBcrazy BluBeam
http://www.getfpv.com/5-8ghz-blubeam-whip.html
i hope so too:)
i just ordered the same combo, mostly because of the small size of the transmitter, AND your comment :)
i don't need 1Km, probably 200-300meters,
how do you install this?
do i need a hub, do i cut my PH2 open?
thx!
GhostMaster said:
This is cheap and works very well:
Boscam TS353 400mw: http://j.mp/1gJ6t7s
Boscam 7" RX-LCD5802 5.8GHz Diversity Receiver: http://j.mp/1lZuham
LCD Battery Charger: http://j.mp/1h3CreQ
With stock antennas you should get arround 1km range, changing antennas you could get 2km+. I recommend helical and cloverleaf.
[youtube]http://www.youtube.com/watch?v=Te9VbVg9EUM[/youtube]
Total price with antennas will be arround 250$.
You can get a 10$ cupon to Banggood if you register here: http://j.mp/RkDaDl
Ghost,
I am looking at the same setup as above. I am curious what the exact antennas you are using for this flight are?
Ghost,
Helical from circular wireless its the best money can get: https://www.circular-wireless.com/produ ... liaxial58/
And boscam cloverleaf antennas, cloud spirit ones.
1. DJI AVL-58
2. iOSD mini
3. DJI FPV Hub
4. Boscam 5802 Rx Monitor
5. Fatshark Spironet Antenna (Or u can use the matching DJI Cloverleafs)
Where can I get all of this in a bundle?
Hey Brad, so this is the set up you went with?
How is it working for you?
Hi all. New to this.
So far I have ordered the: DJI Phantom 2 with the HS-S3 Gimbal + GoPro 3 Black+
What I'm after is a good FPV solution, I was wondering if there is any updates regarding good packages and also would it be worth considering the extra money and going for the LightBridge solution, I think LightBridge is going for about a $1000.00 but what excites me about it, is if I am correct, it has iPad integration. I like the idea of using the one device for both LightBridge and Ground Station, not to mention if I upgrade my quad I should be able to transfer these products.
Sorry for the daft inquiry.
Can any one recommend any bundles that come complete, don't mind soldering. Thanks.
