Range questions
rrmccabe said:
UKFlyer said:
I find the site easy to navigate and see what you need.
http://fpvlr.com/shop/index.php?route=product/product&product_id=110
http://fpvlr.com/shop/index.php?route=product/product&path=70_61&product_id=58
There are tabs at the top of the screen with all the different catagories, i see no problem here.
Actually, that still doesnt do what I need. How do I connect a pair of those antennas? Missing something?
Well you would need the cables to connect them, i imagine similar ones to the sma cables for the tx side but i'm not sure of the exact names as i do not want them but if i did i would do some research and i'm sure all will be explained here http://www.phantompilots.com/viewtopic.php?f=27&t=12712 No need to be keep asking the same questions as you say.
UKFlyer said:
The first picture's control antenna is positioned for when flying overhead.
second picture is the correct way for forward flying. larry8801 :D
I see your links you posted. That looks different than the stage 2 kits. Correct?
Well I don't know ;) I would assume you need a splitter to run two pinwheels for each band. Only one connector on the bird?
Yes those links i posted are to upgrade the quad if you need it. I've not upgraded the quad, only the tx. My kit is here.
http://fpvlr.com/shop/index.php?route=product/product&product_id=103
you sure you read through all 157 pages?
Gotcha, thanks!
I probably will end up upgrading the transmitter with the stage 2 kit.
In addition to the stage 2 kit, how much added benefit is it to upgrade the quad with those antennas? Is there any documented performance gains with those antennas in addition to the stage 2 kit?
Haha, I am just part way.
dlr11164
