Quanum 2.4GHz Telemetry System Setup ??
Hi All
I just received my Quanum telemtry today, but i dont really know how it should be setup, does anyone have this, and know it maybe?
I have 2 Alarms of the Lipo voltage. the standard settings is:
1st alarm: 3.5v
2nd alarm 3.3v
Is it correct? or is it too low?
Also there is a setting called "Total voltage alarm" and the default setting is 19.8v ?
you can see the product here:
http://hobbyking.com/hobbyking/stor..._Telemetry_System_Volt_Amp_Temp_mAh_V3_1.html
Regards Nicolai
Srsly no one know this product, or can advise me about what my Cell voltage should be when i should land my phantom?
Don't know where you're going to get cell voltage unless you've tapped the CAN bus. Land before 10.7V would be my recommendation. Once you're at 10.9, you should be getting ready to bring it home.
Guys have you looked at my link? Quanum is a wireless Cell voltage display, i connect a little transmitter to The balance plug of my battery. The transmitter then sends it to the display
If it's a P2, all the balance is handled inside the battery and you can only monitor total voltage by tapping the main supply wires using the voltages I provided above. If it's a P1, I have no clue.
cokersean20
