Pick-n-Pluck Cases, Adhesive Spray?
Merdian, Idaho
I cannot locate the thread/posts where some of you were discussing the pick-n-pluck foam inserts in the Seahorse or other pnp type cases. I recall a post or two indicating that once you have the configuration you want and the foam plucked, you can use some type of adhesive spray on the top surface that hardens and makes the foam stick together better without leaving a sticky residue for your equipment?
What spray is this and where to purchase?
Your direction is appreciated.
ICH
Falcoray
