Perfect Ipad (not mini) holder
Tahiti
Hey flying comrades!
Just for those of you who are using the traditional bigger model of ipad as FPV monitor when flying, here is my new found treasure after haunting one of the many electronic market in Shanghai. Alas, i cannot give you a brand or a model reference number cos i'm not sure there is,just some random chinese brand, but i'm sure something similar can be found overseas. Here is a link on Taobao, chinese ebay, where you can check what they originally sells for.
http://detail.tmall.com/item.htm?id=37191351942
Best perk is that i use the original phone clamp arm, jut took out the phone holder itself. The ipad holder can fit on the same support ball, i just slightly set the arm lower so have more space for fingers on S2 switch. :) works perfect with my ipad air, but can clamp into even bigger, or smaller obviously.
Thought i'd share this found, can be quite useful for bigger monitor as well. Also, it comes with a 1.20m support bendable tube that you can clip on a table or anywhere to set your ipad in an adjustable position.
Good find, good find ! :)
tom sauter
