Not gps calibration. Compass calibration.Yes gps out door, no metal objects, no keys etc near by.
IMU on level table
IMU on level table
John,Just to clarify, there is no such thing as gps calibration. I think you're talking about compass calibration, and yes that's always done outside, ideally in an open field away from any structures.
Don't discount the digital zoom until you use it. When recording in 1080 the 2X zoom crops the 4K sensor, in essence giving you a non degraded image, as you would normally think about digital zoom. The video output is pretty darn good. Apparently this is only supported with the iPad version of the Go App, which could be why they don't talk about it in the manual.Isn't the zoom nothing more than digital zoom? In which case it's rather pointless, and you'd be better off just keeping the widest possible field of view (since it offers more flexibility in post-production), and then if you wanted a "zoom" you could just do a crop on the computer later.
I disagree. I don't care about 4K editing, I only publish 1080. Digital Zoom can influence how you shoot what you are capturing because you can see closer. Post editing can't do that.Yes I totally get that. But you've just re-stated what I was saying, except in a different way. It is pointless doing a digital zoom, which is exactly what you are doing. You are far better off to keep the widest possible view (in 4K), then do whichever digital zoom you want to 1080p in post-production. If you do the zoom on-the-fly, you have cropped out the surrounding landscape which you can never get back.
I did research it, and I provided a demo. For some purposes it's useful. I disagree with you that's it's pointless. You need to consider this is doing something no other cameras in drones can do, and for special purposes, it's useful. If you don't like it, fine. It's not pointless though, only for you maybe.Let me put it like this: shooting at 2x "zoom" is akin to shooting in JPEG as opposed to RAW. Or shooting in black and white as opposed to colour. Or shooting with the 5-megapixel setting as opposed to using a camera's full 24 megapixels (or whatever it is). You are throwing out all sorts of data and opportunities later on. I've been using all sorts of cameras for years and I know how this works. Please do some research on the matter.
I think you guys are missing my point. While flying, having the ABILITY TO ZOOM LETS YOU SEE CLOSER, and this can influence where you spend your time capturing WHILE YOUR FLYING. If you can't see something interesting you might fly right by it, then later in post you'll be kicking yourself and say....., "gee I wish I would have noticed that cougar down there walking around, I would have stuck around and got more footage. That would have been so cool if I had only seen it while I was flying."I agree with AGreenway on this. If you do the zoom post editing you are able to accurately control the zoom range, speed and position. If you try and do this in-flight you will never be as accurate.
Far better to record as much area as you can and edit it later.
I also do not find a 2x zoom???I'm finding little things here and there to share. Please post any tips you may come across.
1. The new digital assistant 2 released a couple days ago seems to work OK now. The sensor calibration works, when before the start button was always dim and disabled.
2. When doing a sensor calibration, make sure your mouse IS NOT positioned over the dot patterns, as that will make the process very frustrating, believe me.
3. Zoom camera is very cool. Even though it's only 2X, it's quite nice and pretty clear. I really like it, except for the jerky graduation when zooming slowly. It's best to zoom in and out fast, so it instantly goes from 1X to 2X or back to 1X, nothing in between. Just make sure your subject is in the center before you zoom. FYI, I think this only works on the iPad version of Go App for now. Here's a sample of the quality when recording in 1080.
It's only works on iOS .I also do not find a 2x zoom???
Always check your "Transmission Quality" to insure it's set to 4mbps. It appears that RC firmware upgrades may reset this to 10mbps, which will greatly hinder range capability. I was only getting a mile with windsurfer installed on the antennas. After setting to 4mbps (like my P3P) I'm getting 3mi now. The P4 battery can handle a 3mi range (total 6mil trip) more comfortably, given the extra few minutes flight time you get from P4 vs. P3.
To set "Transmission Quality", click the HD icon in the top right area of the Go app screen. You must be connected to the bird, so everything must be on. Click Custom, select a channel such as Ch#20. In manual channel mode the Transmission Quality slider bar will appear. Slide the bar all the way to the left to the lowest setting, 4mbps. Close the HD screen, you're set to fly.
I have a new ipad air2 and updated yesterday. I do not see anything to do it.It's only works on iOS .
Keep in mind, the auto channel function is only controlling the video. The control signal of the craft is separate, unaffected by selecting custom channels or auto select. If you were to lose video you typically still have control of the craft. In the case of losing video signal, ascending 50 to 100' can often regain your video signal, triggering you to cease flying further from home. Optionally you can initiate RTH if this fails. Manually selecting channels 29 through 32 (using the channel hack) almost eliminates the possibility of interference due to very few using those frequencies, they aren't part of the typical computer wifi frequencies. Using 4mbps can double your range compared to 10mbps, and the degradation to the display quality on the tablet is hardly noticeable. It's a good trade-off.Is there no way to reduce the transmission quality while keeping automatic channel selection? I'm worried that I might fly in an area with disturbances and when it can't switch to a better channel, lose connection.
There's nothing in the manual about this. When capturing in 1080, while flying, on the ipad touch screen, with two fingers, pinch to zoom out, spread to zoom in. This also works in 2.7K, but not in 4K mode.I have a new ipad air2 and updated yesterday. I do not see anything to do it.
