P4 RC ANTENNAS
What is the left anntena, and the right one antenna do?
Is one to transmit, and other recieve?
And by using p4 drone anntena
How does ite-dbs02 anntena recieve the hd signal?
If the p4 drone is shooting HD signal, at5000-6000FT
and if you modify the Attenna, with an upgrade, the ite-dbs02 anntenna.
You get a boost of 9000FT from the HD signal
And now im confused how you can get plus boost to 9000 feet???
When the P4 drone is still shooting the same amount hd signal
Will the ite-dbs02 act as better reciever also? And at same time transmit long distance
The quality of the antenna wire and the antenna gains give better results.
Read more about annena gain: Antenna gain explained - Welcome to TP-LINK
Antenna Gain Explained | ZCG Scalar
Basically the higher the gain, the tighter more focused signal is coming out so its not as spread as wide.
The stock phantom are omni directional which bascailly means it transmits all around 360. a Front facing antenna focus all energy directly to the front give a further signal reach rather than it being wasted all around.
Digitdrew
