P4 Checklist on Remote Control
Wanted to share with the Group my solution for having a comprehensive pre-flight checklist always ready and available. The asterisk settings are my typical defaults. The list originates as a Visio Drawing file that is printed onto an 8-1/2" X 11" clear adhesive label sheet (Avery #8665). I print 2 to a sheet in case I screw up and need a 2nd label. I then trim the label carefully with an Xacto blade. Thoroughly clean the RC case with rubbing alcohol before mounting. Temporarily mount the label with masking tape. Carefully peel off the label backing, working from the center out, slowing pressing the label working out any air bubbles from the center to the outside. I can make the Visio file or a PDF available if you email me at [email protected].
Very nice, that looks great!
rockymountaincaptures
