One motor stop First
Try asking for a warrenty replacement motor.
Sticky or defective bearing ... almost a guarantee... turn it with your fingers and see if it has more resistance than the others... tear it down and see if there's any hair or grass or something wrapped around the shaft near the bearings :ugeek:
I just noticed recently that mine is doing the same thing. Curious to know if I need to take the motor apart. Is there a good youtube video on how to do this?
fromadroneseye said:
Here is the video! the Motor that stops first is a CCW?
Thanks in advance for the help!
[vimeo]https://vimeo.com/103954637[/vimeo]
Did you do as instructed above? You can open the motor up and see if there is something inside that is binding around the post. Also, you will want to edit your post and just leave the numbers between the vimeo tag. This way it will actually embed your video.
Do you know what tools i need in other to do what you suggest? thanks
DonT
