It depends. Most North Americans using NTSC will choose 30 FPS for normal Video and possibly 60 or 120 FPS if they are planning to do slow motion in post processing. Europe traditionally uses PAL and the usual FPS of choice will be factor of 25FPS. In addition to Frames Per Second shutter speed plays an important part to obtain "traditional results" Traditionally the shutter speed is the reciprocal of twice the Frame rate So if you are filming at 30FPS your shutter speed will be 1/60 of a second. However Unless you are using ND filters to reduce the light (like sunglasses) you will be forced to use auto since the Phantom 4 has a fixed aperture of 2.8. To my eyes, Shutter speed has less effect the higher or farther away you are from your subject..
