Litchi home point?
Is there a difference between setting up home point with litchi vs dji go? Finally downloaded litchi and for some reason the drone won't set home point and drifts a lot.
Sent from my SM-G935V using PhantomPilots mobile app
It's the same. There must be some other reasons for drift.
Litchi Does not "Audibly" tell you the home point update. Just check the map and you should be good. The drift is most likely unrelated.
src72
