Just a quick note to even things out...
I heat the shell up for 15 seconds just before I drop it into the dye. Before I do anything I boil the dye in a pot, then transfer that heated dye into a rubbermaid container and Drop the body into it and leave it. I do the same process with my traxxas stuff. I dont care for the black bodies I did it for my buddy. The nice and clean white body is more my speed. Ill see if I can find a pic for you, or maybe Ill dye a set of landing gear I have here
How much dye would you need for a shell?
I think 1 guy did. I think it's to think tho and would just fill in the vent holes. Also I have had bad luck with installing screws after plasti dipping stuff. When the screw starts to grab it will grab the plasti dip and start to peel it off.
Push silly putty in from the back side. That will take care of filling holes and vents. Ive used it quite a bit on other projects.
