ladykate said:Your props are shading the sun as they rotate. You camera is using a fast exposure rate which captures the shading. It causes a perceived flutter - which looks like vibration jello (sorta). Thus, the solution is to either fly away from the sun (can't in midday) or get an ND filter so the sync up of the shadows of the prop are spread out and not (as) noticeable.
adanac said:I'm not sure I agree an ND filter would help with prop shadow but let's not get off topic. I don't think it's prop shadow, I think it's jello.
ianwood said:To understand "jello" better, read this:
http://www.diyphotography.net/everythin ... g-shutter/
An ND is the only way to deal with it effectively. An ND might also help with prop shadows but I've seen prop shadows with the ND as well. The only way to truly keep the shadows out is to use a visor or not have the light source at angle such that it passes through the props before entering the lens.
adanac said:Thank you. I understand how a rolling shutter creates jello, I'm just not sure I understand how slowing down my shutter speed helps. I'm wondering if it would go away if I shot at 30fps instead. I also don't know which filter to get as I can't find any recommendations. Lastly, I would prefer a polarizer, which might also provide an associated loss of 1-2 stops.
I only get it in bright daylight. At other times everything is rock solid (knock on wood) and great.
ianwood said:The higher the shutter speed, the more the rolling shutter is noticeable. If an object is in motion relative to the camera, a rolling shutter will distort the object proportionally to its speed. The shorter the exposure, the less the object's motion is captured making the distortion more noticeable. A lower shutter speed will blur an object in motion creating a smoother transition between frames making the distortion less noticeable.
Reducing FPS may reduce shutter speed but not necessarily. You don't want to use a polarizer unless you are filming near water, snow or other highly reflective surfaces.
ianwood said:The sensor should always scan at full speed. When the shutter speed is slowed down, the sensor will make more top to bottom scans per frame (thus increasing exposure). More scans per frame will give you a more complete and smooth image as the object moves relative to the camera.
