You can already achieve this stock... 800 meter control distance FCC mode... if you use the booster app for increased FPV, you've already far exceeded your control range... no antenna upgrade needed for 1000 ftJWarren said:I'm not real tech savy, but I want to be able to go more than 1000ft vertical and especially horizontal. Any suggestions?
JWarren said:I actually did the coke can mod tonight and that got me cruising around at 1500. Without doubt an improvement. I was having LOS occur at 1000 and unable to maintain 1000. I'm happy with 1500ft, so now I'm going to have a more permanent version of the coke can mode machined at a shop soon.
srandall25 said:JWarren said:I actually did the coke can mod tonight and that got me cruising around at 1500. Without doubt an improvement. I was having LOS occur at 1000 and unable to maintain 1000. I'm happy with 1500ft, so now I'm going to have a more permanent version of the coke can mode machined at a shop soon.
interesting.... I routinely get 1500' with my stock antenna. What do you mean that you was having LOS occur at 1000 ? You should always have line of sight with your Phantom / antennas... Ensure LOS throughout your flight and you should achieve over 1500' with stock antenna...
haha... i guess so.. it also means Line of Sight. but in his case you would be correct... must be my military background...tizzl10 said:srandall25 said:JWarren said:I actually did the coke can mod tonight and that got me cruising around at 1500. Without doubt an improvement. I was having LOS occur at 1000 and unable to maintain 1000. I'm happy with 1500ft, so now I'm going to have a more permanent version of the coke can mode machined at a shop soon.
LOS also means "loss of signal".
