How to mount a Tarot T-2D V2 on a phantom 2
I actually have the Tarot already, just try to figure out how people mounted it under a phantom 2
I thought it would be popular but apparently not that much.
It was a tarot mounting plate for about £3. Plenty of low cost ones on Amazon, eBay, aliexpress. Mostly shipped from China.
Interesting that some people have rated the Tarot far higher than the Zenmuse one at four times the price.
I had the same problem lucky there is a solution purchase this mount http://www.ebay.com/itm/Aluminium-A...01?pt=LH_DefaultDomain_0&hash=item419128ae39#problem solved! This is the only mount that will work with a Tarot V2 on a P2. You will still have to extend the legs because the camera will touch the ground. I just used wooden dowels to extend the legs with zip ties but there are much better solutions. Send me an email at [email protected] if you have any more questions regarding the tarot v2 installation on a P2.
Thanks Dano and Landmannnn for your help !
I came across this aluminium mount, I think I'll go for that.
If you need some simple 10mm risers to work with the Tarot T2D gimbal check these out: http://www.ebay.co.uk/itm/131468861055
Very light weight.
Screen Shot 2015-04-01 at 11.39.33.png Screen Shot 2015-04-01 at 11.39.40.png
