Hanatora Charger for P4 Batteries
I just received a Hanatora parallel charger for P4 batteries and the controller. The charger output is 17.6v, the batteries clearly state 17.4v maximum. Should I send this back? Has anyone else used this charger?
Hello. In response to your query, there is no problem that you use that charger, since the difference in voltage applied by the charger to the batteries is only 0.2 Volts. It is a negligible voltage that will not affect the batteries during their charging, so rest assured that this charger will not damage the batteries of your drone at all. Good luck! ?
hcashmore11
