GPS Out of Service as of 07/15/2019
It has no effect on most DJI gear as most use USA based GPS and Russian GLONAS.
Galileo is not actually operational ... it is STILL in test phase ... and what has happened now is one of the ground stations that corrects / monitors the timing has failed .....
24 sats are in position - but 3 are still test-mode with 21 working - but in error due to this ground station fault.
People may be surprised to know that there are another two systems as well ... Indian (in development / testing) and Chinese (operational) ... but these are also NOT used by DJI.
Thanks for the feedback. Happy landings!
how are all the satellites always there.
The same satellites aren't always there.
Over time you are seeing different satellites.
Here's a simplified animation to demonstrate:
Off Topic, well not really ;)
I got curious, it had seen it in a few years.....
Check out this link:
You wouldn't think there would be the talk of global warming, all the stuff between the Earth and Sun. :rolleyes:
Rod
Rod
That's a scary thought between these 2 areas,earth and sun,makes you wondero_O
Reactions: RodPad
fredkamphues
