Got critically low battery at 42 percent?
Discussion in 'Pro/Adv Discussion' started by IceFireSoul, Aug 16, 2015.
  1. IceFireSoul
    This happened today while flying above the sea... Never had happened before, ever. I was flying near a military base. What could have caused it?
  2. Oesau
    Sydney, Australia
    So you got the critical alert at 42%? Have you validated the alert settings in the DJI Go app?
    Also - do you remember what the actual voltage of the battery was at that time rather than just the %?
  3. bobmyers
    San Antonio, TX
    Your battery may not have been properly seated--- has happened before to several of us.
  4. Fplvert
    Southern Idaho USA
    Also, check the contacts. They need to be clean.
    You can hold down the power button of the battery to check its life, or check it in the app.
  5. IceFireSoul
    Not properly seated? Like what?
  6. bobmyers
    San Antonio, TX
    Like you can shove the battery in and it appears to be seated, but it is not locked. a sure check in to look at the gap where the battery meets the housing, if there is ANY gap -- even 1mm it is not seated. You will think it is seated, but in fact--it is not and the vibrations of flying will cause it to back out and show the wrong readings or give a battery error. It has happened to several on this forum including me.
Similar Threads - Got critically low Forum Date
Just got my P4 ~ Problem viewing video on my PC Phantom 4 Help Jul 24, 2017
Forgot the #$&! MicroSD card Phantom 4 Discussion Jul 22, 2017
Standard I think I have got my gimbal problem narrowed down. Phantom 3 Help Jul 14, 2017
Had a flight .. forgot to remove foam gimbal pad from rear. Phantom 4 Discussion Jul 13, 2017
Latest firmware got people crazy!! Should I?? Phantom 4 Discussion Jul 10, 2017
