Gimble issue
Hii guys, there is an issue with my aircraft's gimble. When I turn on the unit gimble acts weirdly. I always have to restart the drone. Some time I have to give a little push to calibrate the gimble otherwise no image transmission kicks out. Never crashed before. I ll upload two videos. Hope you guys ll suggest me a solution. Thank you in advance. :)))
Please check the below video.(usually, after the restart gimble acts normally. But sometimes not. I have to restart again. However this time it acted normally
Hello. I have the same issue with the last firmware. I try to put lens to gimble (the P3 was off) and then when i power up there was this issue.
When i start the P3 with a new inserted battery the problem occurs.
After that gimble start to work (even with some help) and try on/off again when i don't eject the battery everything is ok. As long i eject it and leave it some time and re-inserted, i have the problems...
Any solution?
muskansahu
